towing capabilities
Old Mar 6, 2014 | 06:49 PM
ericcarr2000's Avatar
ericcarr2000
Does this mean the maximum weight I can tow is 7350?Wt Distributing Hitch - Max Trailer Wt.7350 lbs (7350.0 min/7350.0max)
Old Mar 6, 2014 | 06:52 PM
ericcarr2000
I do remember having to replace both my trans cooler lines towards the front of the motor though.
Originally Posted by dxloat
It is not necessary to post you vin here just use the vin decoder link in the guy aboves post. The cooler your seeing is probably the AC radiator, sorry I forgot to mention that before, it would be in front of that. From what you are saying I am guessing you don't have the optional factory tow package but check the vin to be sure.
Old Mar 6, 2014 | 06:57 PM
dxloat's Avatar
dxloat
GAWR = Gross Axel Weight Rating
I see the vin decoder dose not say which gear ratio yours has, just that the max is 7350lbs. The 7350 is with the 3.92 gears. You need to find that tag or get a build sheet.
Old Mar 6, 2014 | 07:07 PM
ericcarr2000
I do remember when I had to replace my front differential it had a 3.55 in it I'm pretty sure.
Old Mar 6, 2014 | 07:11 PM
dxloat's Avatar
dxloat
It really depends on how far you plan on towing to some degree. The truck structurally and braking is capable but the drive train may not be optimal for towing long distances or up hill say in the mountains if you don't have the tow package.
Your vin does show a 6000 to 7000 tow capacity, but I would still try to verify the gears depending on the towing your doing.
Old Mar 6, 2014 | 07:33 PM
dxloat's Avatar
dxloat
There is a decal on the axles, generally on the top. If you crawl under the truck you can weasel a peek with a little effort, or possibly see the little metal tag on the diff cover. Sometimes they have the little metal tag and sometimes they dont, I think they get lost when the diffs are serviced.
Old Mar 6, 2014 | 07:35 PM
PublicHair's Avatar
PublicHair
Gear tag on axle.
If you have the HD tow package then you are pre wired for trailer brakes. My harness adaptor was found in the rear cargo bin.
Old Mar 6, 2014 | 08:57 PM
gvsu4msu's Avatar
gvsu4msu
Originally Posted by ericcarr2000
And the VIN is, 1B4HS28Z01F528189
You can get a build sheet by requesting it here:
http://www.dodge.com/webselfservice/...ull&category=U
I got a reply in 2 business days.
Old Mar 6, 2014 | 09:10 PM
PublicHair's Avatar
PublicHair
Here was my build sheet I got last year:
Dear Adam:
Thank you for contacting the Dodge Customer Assistance Center regarding
your 2001 DODGE DURANGO 4X4 SPORT UTILITY 4-DR
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
VIN 1B4HS28NX1F519772
Vehicle Description DODGE DURANGO 4X4 SPORT UTILITY 4-DR
Model Year 2001
Body Model DN 5 L 74
Color PS4- Bright Platinum Metallic Clear Coat
Engine EVA- 4.7L V8 MPI Engine
Transmission DG4- Multi-Speed Auto 45RFE Transmission
*GJ Leather Trimmed Bucket Seats
-DV Dark Slate Gray
ADAS Light Group
ADJP Heavy Duty Service Group
AFHP Interior Convenience Group
AGWP 18" Off-Road Tire & Wheel Delete
AHC Trailer Tow Group
AJBP Security Group
AJKS Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
ATK SLT Plus Decor Group
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BABP 160 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BCSS Battery Run Down Protection
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CADP High Back Bucket Seats
CBZP Prem Vinyl Door Trim w/Map Pocket
CFMP Rear Folding Seat
CFP 3rd Row Seat
CGWS Next Generation Front Air Bags**
CJTS Delete Front Center Seat
CKAS Carpets - Floor and Cargo Area
CKTS Cargo Tie Down Loops
CLEP Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUCP Floor Console
CUNP Overhead Console
CURS Rear Compartment Storage Tray
DGBS All 4-Speed Automatic Transmissions
DG4 Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EAAC All Engines
EVA 4.7L V8 MPI Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFAS Rear Window Defroster
GNCP Sun Visors w/Illum Vanity Mirrors
GNTP Rear View Auto Dim Mirror
GTSP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXRS Keyless Entry
GXXP Sentry Key Theft Deterrent System
HADS Air Cond'ing w/Dual Zone Temp Cntrl
HBB Rear Air Conditioning w/Heater
HGAS Hood Insulation
I81S Route 81 - UP, Centreville, IL
JAMP Soft Touch Instr. Panel w/Woodgrain
JAYS Instrument Cluster w/Tach
JBFS Instrument Panel Black Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHDS Rear Var Intermittent Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JJMS Auxiliary 12-Volt Rear Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JT3P Power Driver/Pass 8-Way Heated Seats
K2EP STRIPE/BADGE/MOLDING/COLOR
K5EP STRIPE/BADGE/MOLDING/COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LANS Decklid/Liftgate Ajar Warning Lamp
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LCDP Map/Dome Reading Lamps
LDGS Liftgate Flood Lamps
LMBS Halogen Headlamps
LNJP Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MBQP Body Color Rear Bumper w/Step Pads
MDAP Front License Plate Bracket
MFNS Body Color Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MLHP Body Color Front Fascia
MRLP Body Color Running Boards
MURP Dodge Badge
MUSP 4X4 Badge
MUZP SLT Badge
MWGP Roof Rack
MWHS Rear Wheelhouse Liners
MZJP Durango Bright Badge
NAA Federal Emissions
NBKS EVAP Control System
NF4S 25 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHCS Oil Level Sensor
NHFP Power Steering Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PS4 Bright Platinum Metallic Clear Coat
QS4S Bright Platinum Clear Coat
RAAC All Radio Equipped Vehicles
RAZP AM/FM Cassette Compact Disc Radio
RCTP 8 Infinity Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXVP P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WD1P 16X8.0 Cast Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XDXS Scissor Type Jack
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
XGDP Universal Garage Door Opener
YAAS Build To U.S. Mkt. Specifications
If we can be of any assistance in the future, please email or contact
Customer Care Center by telephone at 1-800-4aDodge (800-423-6343)
Thanks again for your email.
Sincerely,
Alex
Customer Service Representative
Old Mar 6, 2014 | 09:14 PM
ericcarr2000
As far as the length of towing, I probably wont be going more than an hour away and most of it is mainly highway, with the exception of pulling the boat up the launch ramp...That's where I'm concerned mainly...I'm really not concerned about the braking because the trailer does have surge brakes on it.
