Code p0440 is driving me batsh*t crazy!
Old Mar 6, 2014 | 07:29 PM
jqthomas's Avatar
jqthomas
Default Code p0440 is driving me batsh*t crazy!
My 4.7 liter 2003 Durango is throwing the p0440 code.... I have replaced ALL of the hoses and the gas cap.... What is the next thing to check? I refuse to take this to the shop.
Old Mar 7, 2014 | 01:31 AM
that_guy's Avatar
that_guy
Did you ever reset the code?
Old Mar 7, 2014 | 06:08 AM
jqthomas's Avatar
jqthomas
I had the battery disconnected for the entire hour it took to replace all the hoses....shouldn't that have reset the code?
Old Mar 7, 2014 | 06:59 AM
vako's Avatar
vako
i had this problem on my dodge , and tireplus store took 5 visit for them to really fix it, if you changed all hoses maybe the sensors?
Old Mar 7, 2014 | 07:01 AM
jqthomas's Avatar
jqthomas
Which sensors, exactly?
Old Mar 7, 2014 | 09:06 AM
DyingBreed's Avatar
DyingBreed
No. You have to disconnect the battery and turn key on in the ignition for 15-30 seconds I can't remember how long exactly. I just hold it on for 30 to make sure all power is drained. Or it will reset itself after so many cold starts. I think it's around 50.
Old Mar 7, 2014 | 05:59 PM
wlarocque's Avatar
wlarocque
I'm having the exact same issue as the OP - P0440. I have replaced all the rubber hoses under the durango and the ones under the hood. I have replaced the gas cap, and yes I have reset the CEL each time I do something, but it eventually pops back on. Are there any rubber hoses on top of the fuel tank? I have not drop the tank to check. Like the OP I would be very interested in any other ideas on where to proceed next. Thanks
PS I also have a 2003 4.7L
Old Mar 9, 2014 | 04:13 PM
Blk Panther's Avatar
Blk Panther
02 same deal here , on and off for 2 years . new hoses everywhere , new purge valve canister , never did the pump underneath but heard its almost never that . also heard the small can under the purge valve could be it . gotta pull battery tray out to get to it. if anyone knows please help us all , tired of lookin at that light
Old Mar 9, 2014 | 10:05 PM
autoshh's Avatar
autoshh
I still haven't had any confirmation, but I was having PS issues, and after replacing both PS lines, my codes stopped, so I'd give yours a check. If they're fine, don't bother replacing them. If they're not, it's worth a try, since that stopped mine.
Old Mar 11, 2014 | 11:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
P0440-GENERAL EVAP SYSTEM FAILURE
Theory of Operation
The Evap Purge Monitor tests the integrity of the hoses/tube between the throttle body/intake and the fuel tank. The monitor is a two stage test and runs only after the Evap system passes the small leak test. Stage one is non-intrusive. The PCM monitors the purge vapor ratio and the ESM switch closed ratio. If the purge vapor ratio is above a calculated value, the monitor passes. If the ESM switch closed ratio is greater than calculated value when purge flow is greater than a minimum value, the monitor passes. Stage two is an intrusive test and runs only if stage one does not pass. The PCM commands the purge solenoid to flow at a specified rate to force the purge vapor ratio to update. The ratio is compared to a calibrated specification. If it is less than specified, a one trip failure is recorded. This test can detect if the purge hose is off, obstructed, or the purge valve is not operational.
•When Monitored:
Engine running after a cold start with the difference between ECT and AAT is less than 10° C (19° F). Fuel Level between 12% and 88% full. Manifold vacuum greater than a calculated minimum value. Ambient Temperature between 4° C and 32° C (39° F and 89° F).
•Set Condition:
When the monitor conditions are met, the PCM will ramp in purge flow. If the PCM does not sense an ESM switch closure after a calculated amount of purge flow accumulation, an error is detected. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
EVAP PURGE SOLENOID VACUUM SUPPLY
EVAP PURGE HOSE/TUBE AND FRESH AIR FILTER OBSTRUCTION
(Z910) GROUND CIRCUIT OPEN
(K107) ESM SIGNAL CIRCUIT OPEN
EVAPORATIVE EMISSION LEAK
EVAP SYSTEM MONITOR SWITCH
EVAP PURGE SOLENOID
POWERTRAIN CONTROL MODULE (PCM)
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
1.VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
1. Ignition on, engine not running.
2. With a scan tool, select View DTCs. Record the related Freeze Frame data if any DTC(s) are present.
3. Whether or not any DTC(s) are active you will want to check the following items which may assist in repairing the customer's complaint successfully.
4. Check the vehicle's repair history.
5. If the vehicle has a repair history that pertains to the customer's current complaint, review the repair.
6. Inspect the vehicle for any aftermarket accessories that may have been installed incorrectly.
7. Check for any service bulletin(s) related to the customer's complaint or DTCs.
8. If a service bulletin applies, follow the instructions per the service bulletin.
Choose the following scenario that best applies.
The service bulletin repaired the customer's complaint.
•Testing complete.
A DTC is present, no service bulletins apply, or the service bulletin didn't repair the customer's complaint.
•Go To 2
2.ACTIVE DTC
NOTE: Allow the vehicle to reach ambient temperature before continuing with this procedure.
NOTE: A loose gas cap could have caused this DTC to set. Make sure the gas cap is tight and in good condition.
NOTE: If the customer is experiencing an early fuel shut off during the fuel filling process along with P0440, P0441, and P0452 setting, you need to check for restrictions in the EVAP Purge tubes/hoses as well as the Fresh Air Filter before continuing.
1. Start the engine.
2. Allow the engine to reach normal operating temperature.
3. With a scan tool, select View DTCs.
NOTE: It may be necessary to drive the vehicle to meet the conditions to set this DTC, try to repeat the conditions in which the fault originally set by reviewing the Freeze Frame data.
Is the DTC Active or Pending at this time?
Yes
•Go To 3
No
•Refer to the INTERMITTENT CONDITION Diagnostic Procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
3.VISUAL AND PHYSICAL INSPECTION
1. Turn the ignition off.
2. Perform a visual and physical inspection of the entire Evaporative Emission system.
3. Check for the following conditions:
•Hoses disconnected or left off
•Holes or cracks
•Loose seal points
•Evidence of damaged components
•Incorrect routing of hoses and tubes
•Fuel Cap left off or bad gasket seal
Were any of the above conditions found?
Yes
•Repair as necessary.
•Perform the POWERTRAIN VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
No
•Go To 4
4.EVAP VACUUM SUPPLY HOSE INSPECTION
1. Carefully inspect the Evap Purge Solenoid vacuum supply hose for proper routing.
2. Check for a pinched or plugged hose from the throttle body or intake manifold to the Purge Solenoid.
3. Make sure the vacuum port at the throttle body or intake manifold is free from any blockage.
Were any problems found?
Yes
•Repair the vacuum supply, hose/tube as necessary.
No
•Go To 5
5.EVAP PURGE SOLENOID
NOTE: To continue testing you will need Miller Tool 8404B Evaporative Emission Leak Detector (EELD).
WARNING: Keep lit cigarettes, sparks, flames, and other ignition sources away from the test area to prevent the ignition of explosive gases, Keep the test area well ventilated.
1. Connect the red power lead of the EELD to the battery positive terminal and the black ground lead to battery negative terminal.
2. Disconnect the vacuum hoses at the Evap Purge Solenoid.
3. Connect the SMOKE supply tip (black hose) to the “CAN” port on the Evap Purge Solenoid.
4. Set the smoke/air control switch to SMOKE.
5. While still holding the remote smoke/air start button, check to see if smoke is exiting the purge valve. This indicates that there is a leak internal to the purge valve.
NOTE: This is an optional method of checking the purge valve for leaks if the EELD is unavailable.
6. Disconnect the Smoke supply tip from the vacuum supply hoses at the EVAP Purge Solenoid.
7. Using a hand vacuum pump, apply 10 in Hg to the "CAN" side of the EVAP Purge Solenoid.
8. Observe the vacuum gauge for at least 15 seconds.
Is smoke visible from the EVAP Purge Solenoid or NOT hold a vacuum?
Yes
•Verify that there is good pin to terminal contact in the Solenoid and Powertrain Control Module connectors. Replace the Evap Purge Solenoid if no problems were found in the connectors.
No
•Go To 6
6.ESIM SWITCH STATE
2. Connect the previously disconnected vacuum hose.
3. Disconnect the Evap System Monitor Switch harness connector.
4. Ignition on, engine not running.
5. Monitor the ESIM Switch state on the scan tool.
6. Carefully connect a jumper wire between the (K107) ESM Signal circuit and the (Z910) Ground circuit in the Evap System Monitor Switch harness connector.
7. Monitor the ESIM Switch state on the scan tool.
Did the Switch change from OPEN to CLOSED when the jumper wire was installed?
Yes
•Go To 9
No
•Go To 7
7.EXCESSIVE RESISTANCE IN THE (K107) ESM SIGNAL CIRCUIT
2. Disconnect the C3 PCM harness connector.
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals resulting in poor terminal to pin connection. Install the PCM Pinout Box Kit, NGC, 38 Position 8815A to perform diagnosis.
3. Measure the resistance of the (K107) ESM Signal circuit from the ESM harness connector to the appropriate terminal of special tool 8815A .
Is the resistance below 5.0 ohms?
Yes
•Go To 8
No
•Repair the excessive resistance in the (K107) ESM Signal circuit.
8.EXCESSIVE RESISTANCE IN THE (Z910) GROUND CIRCUIT
1. Using a 12-volt test light connected to B+, probe the (Z910) Ground circuit in the ESM harness connector.
NOTE: The test light should illuminate brightly. Compare the brightness to that of a direct connection to B- (ground).
Does the test light illuminate brightly?
Yes
•Go To 14
No
•Repair the excessive resistance in the (Z910) Ground circuit.
9.VERIFY EVAPORATIVE EMISSION LEAK
WARNING: Keep lit cigarettes, sparks, flames, and other ignition sources away from the test area to prevent the ignition of explosive gases. Keep the test area well ventilated. Failure to do so may result in possible serious or fatal injury.
2. To continue testing you will need Miller Tool 8404B Evaporative Emission Leak Detector (EELD).
NOTE: The fuel tank should have between 20% and 80% of fuel tank capacity to properly test the Evap system.
3. Connect the red power lead of EELD to the battery positive terminal and the black ground lead to battery negative terminal.
4. Block the vent hose of the EVAP Canister.
5. Connect shop air to the EELD.
6. Set the smoke/air control switch to AIR.
7. Insert the tester's AIR supply tip (clear hose) into the .040 orifice on the tester's control panel.
8. Press the remote smoke/air start button.
9. Position the red flag on the air flow meter so it is aligned with the indicator ball.
10. When the calibration is complete, release the remote button. The EELD flow meter is now calibrated in liters per minute.
11. Install the service port adapter 8404-14 on the vehicle's service port (if equipped) or install the 8404-ADP into the filter line.
12. Connect the Air supply hose from the EELD to the service port (if equipped) or to the 8404-ADP adapter.
13. Press the remote button to activate AIR flow.
14. Compare the flow meter indicator ball reading to the red flag.
15. ABOVE the red flag indicates a leak present.
16. BELOW the red flag indicates a sealed system.
Is the indicator ball above the red flag?
Yes
•Go To 10
No
•Go To 12
10.EVAPORATIVE EMISSION LEAK DETECTION
NOTE: A thorough visual inspection of the Evap system hoses, tubes, and connections may save time in your diagnosis. Look for any physical damage or signs of wetness at connections. The strong smell of fuel vapors may aid diagnosis also.
1. Remove the Air supply hose from the service port or the 8404-ADP adapter.
2. Connect the SMOKE supply tip (black hose) to the service port (if equipped) or to the 8404-ADP adapter.
3. Set the smoke/air control switch to SMOKE.
NOTE: The flow meter indicator ball will not move at this point.
4. Press the remote smoke/air start button.
NOTE: Make sure that smoke has filled the EVAP system by continuing to press the remote smoke/air start button, remove the vehicle fuel cap, and wait for the smoke to exit. Once smoke is indicated reinstall the fuel cap.
NOTE: For optimal performance, introduce smoke into the system for an additional 60 seconds; continue introducing smoke at 15 second intervals, as necessary.
5. While still holding the remote smoke/air start button, use the white light ( 8404-CLL ) to follow the EVAP system path, and look for the source of the leak indicated by exiting smoke.
6. If a leak is concealed from view (i.e., top of fuel tank), release the remote smoke/air start button, and use the ultraviolet (UV) black light 8404-UVL and the yellow goggles 8404-20 to look for residual traces of dye that are left behind by the smoke.
7. The exiting smoke deposits a residual fluid that is either bright green or bright yellow in color when viewed with a UV light.
NOTE: The EVAP System is divided into three zones. A leak from any of these zones can cause this DTC to set. The lists below specify the possible leak points in that specific zone. For further assistance see the Zone Identification Charts below.
ZONE 1
1.Fuel Cap
2.Recirculation Check Valve
3.Vapor Recirculation Line
4.Signal Vapor Line for FVM
5.Flow Management Valve
6.Fuel Tank to Canister Vapor Line
7.Fuel Tank Vent (Check Valve)
8.Vapor Line to Canister
9.Flow Control Orifice
10.Control Valve
11.Liquid Trap
12.Fuel Tank
13.Check valve
14.Fuel Fill Tube to Tank connector
15.Fuel Fill Tube
ZONE 2
1.Filter
2.Evap System Monitor Switch
3.Canister Vent Line
4.Evap Canister
5.Chassis Purge Valve
6.Fuel Tank to Canister Vapor Line connection
7.Evap Purge connection
ZONE 3
1.Evap Purge Vacuum Line
2.Connection to Chassis Line
3.Connection to Canister
4.Chassis Purge Line
5.Evap Purge Vacuum Line
6.Connection to Evap Purge Harness
7.Chassis Evap Purge Line connection to Engine Vacuum
8.Evap Purge Valve
9.Service Port
NOTE: Carefully inspect the vent side of the EVAP Canister. Due to the filtering system in the canister the smoke or dye may or may not be visible. Introducing smoke into the filtered side of the canister may assist in locating the leak.
Select the appropriate response from the list below:
A leak was found at the gas cap or fuel filler tube
•Go To 11
A leak was found in one or more of the EVAP System zones
•If the leak is at a hose connection, remove the hose then reconnect the hose and check for a leak again. All other leaks repair as necessary.
No leaks were detected
•Go To 12
11.LEAK AT GAS CAP
1. Remove the SMOKE supply tip (black hose) from the service port (if equipped) or to the 8404-ADP adapter.
2. Install gas cap adapter, Miller Tool 8382 (1/4 turn cap) or 6922 (screw cap) and 8399 * (secondary seal depressor) and repeat test 5.
NOTE: The gas cap adapter is being used as a known good cap.
Was a leak found at the gas cap adapter?
Yes
•Replace the Fuel Filler tube assembly.
No
•Replace the gas cap.
12.EVAP PURGE HOSE/TUBE AND FRESH AIR FILTER OBSTRUCTION
1. Inspect the Evap Purge hose/tube for proper routing and installation between the Evap Purge Solenoid and the Fuel Tank between the Fuel Tank and the Evap Purge Canister
2. Make sure the hose/tube and fresh air filter are not damaged, kinked, and free from any obstructions.
Yes
•Repair or replace as necessary.
No
•Go To 13
13.EVAP SYSTEM MONITOR SWITCH
1. Use the wiring diagram/schematic as a guide, inspect the wiring and connections between the Evap System Monitor Switch and the PCM.
2. Look for any chafed, pierced, pinched, or partially broken wires.
3. Look for any broken, bent, pushed out, or corroded terminals.
4. Verify that there is good pin to terminal contact in the ESIM Switch and the Powertrain Control Module connectors.
5. Refer to any Technical Service Bulletins that may apply.
Yes
•Repair and Replace as necessary.
No
•Verify that there is good pin to terminal contact in the Switch and Powertrain Control Module connectors. Replace the Evap System Monitor Switch per Service Information if no problems were found in the connectors.
14.POWERTRAIN CONTROL MODULE (PCM)
1. Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Switch, Solenoid, and the Powertrain Control Module (PCM).
3. Look for broken, bent, pushed out or corroded terminals. Verify that there is good pin to terminal contact in the Switch, Solenoid, and Powertrain Control Module connectors.
4. Refer to any Technical Service Bulletins that may apply.
Were there any problems found?
Yes
No
•Replace and program the Powertrain Control Module per Service Information.
