2001 console
Old Apr 21, 2014 | 02:39 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Default 2001 console
I got the 2001 Durango finished that I purchased wrecked awhile back. I'm just working out a couple bugs. I noticed the overhead console doesn't show any readings except for direction. The temp and mpg readings just show two horizontal lines like this -- any idea what to check? Could it be a fuse or something? I assume the temp sensor is bad but I didn't know why the mpg won't display.
Old Apr 21, 2014 | 09:29 AM
hydrashocker's Avatar
hydrashocker
Try to reset the overhead display by holding both buttons in for like 5 seconds. Here: https://dodgeforum.com/forum/1st-gen...d-display.html
Old Apr 21, 2014 | 05:37 PM
Old_School's Avatar
Old_School
Its not making a connection to the Bus System... Mine would do that every so often and later found that the wire for "CCD Bus +" (PCI Bus + on yours) had came loose. Being that yours was wrecked its likely a wire could have got broken in the accident.
Old Apr 26, 2014 | 01:39 AM
dodgedakota98luver
Problem solved thanks guys. The violet wire with a yellow stripe was broken
