45 RFE Trans Hickup in OD
Old May 4, 2014 | 08:30 AM
leebar's Avatar
leebar
Default 45 RFE Trans Hickup in OD
2000 Durango, 4.7, 4WD Sport, 1st Generation, 197K
NO Check Engine Light / Trans was slipping between 2 and 3 with an occasional hiccup in OD(a sudden slight jerk while moving at 57 MPH then smoothed out), Changed fluidand filters, Noticed a bolt in the pan at magnet. Returned bolt to the correcthole and found the other 4 bolts surrounding it lose (center of plate besidelarge filter. Tightened bolts and continued with fluid change. After all wasback in operating order I took the Durango out for a spin. All shifting wentwell and temps are good, and the slippage between 2 and 3 did not appear.However, the hiccup did happen once. I will continue to monitor the transoperation. However, I would like to know if anyone as encountered such issueswith this particular trans and what fixed the problem.
Thank you in advance for your assistance.
Old May 4, 2014 | 03:23 PM
PublicHair's Avatar
PublicHair
Noted.
My hiccup was fixed by using a 2005 jeep grand Cherokee TCM. Also had hard shifts.
Old May 4, 2014 | 11:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
If were not aware that there is a repair kit for the accumulator cover. Mopar number 5174633AB and the kit comes with new accumulator cup and seals. The hiccup maybe from a damage seal on the accumulator cup.
Old May 5, 2014 | 06:42 PM
leebar's Avatar
leebar
Default Thank you
Another hiccup today, but everything else was much better, smooth shifting and pickup. I will try your fix for the hiccup and advise my findings.
Old May 16, 2014 | 01:08 PM
leebar's Avatar
leebar
Talking Reply after replcement of components
This is to provide you with the results after replacement of components; Transmission Speed Input Sensor and Throttle Position Sensor.
Currently all issues went away after replacing both components listed. Transission shifting in all gears are much smoother and no more hiccups in overdrive; 193K miles.
Thank you for your input.
Leebar
