Transfer Case Swap
Old May 26, 2014 | 04:44 PM
that_guy's Avatar
that_guy
Ok im hoping for that then
Old May 26, 2014 | 04:50 PM
Old_School's Avatar
Old_School
Its up to you, just be ready that i could be a 2 pin switch... if that does not work it looks like your gonna have to order the $50 one. Personally i would yank one from the yard...
Old May 26, 2014 | 05:10 PM
that_guy's Avatar
that_guy
If this one isn't the right one ill end up having to get one from the junkyard. Usually the engines and transmissions yet yanked along with thr transfer case almost immediately though.
Old May 30, 2014 | 04:37 PM
that_guy's Avatar
that_guy
Well the switch got here today, but it was only the 2 pin one. I'm going to complain to them and see if they'll do something about it. It does say it's for the 242 case, so it should be 4 pin.
Old May 31, 2014 | 08:28 AM
DJeXeCute's Avatar
DJeXeCute
Yours is the full time one right? I thought the full time cases were nv244
Edit. Yeah the rangos are nv233 and 244 the np231 and 242 are cases I had in my last two jeep Cherokee xjs
Old May 31, 2014 | 09:52 AM
that_guy's Avatar
that_guy
The nv233 and nv244 are the electronically shifted ones from 01-03. The nv231 and nv242 are the mechanically shifted ones from 98-00. Mine is the nv242 which has full time.
Old Jun 2, 2014 | 11:49 AM
hydrashocker's Avatar
hydrashocker
You mean the Part Time function.
I know you've looked at the FSM but I wanted to post this for the others. The harness you want is the 4 prong harness, but there is only 3 usable pins. Looking at the harness connector with the tab up;
A is at top centered = Ground
B is at bottom centered = Full Time 4X4 Sensor
C is on the right middle = Un-Used
D is on the left middle = Part Time Sensor
It is going to be very hard to find this connector at a junk yard, the NV242 case wasn't installed in many trucks. Might want to look into Jeeps.
Old Jun 2, 2014 | 01:28 PM
that_guy's Avatar
that_guy
I meant it has full time compared to the 231.
I did get the wiring jumper that goes from the main wiring to the sensor that has the 4 pin (3 of which are used) connector. I emailed the place I got the wrong switch from with the mopar part number (56006755) to see if they have the right one.
Old Jun 2, 2014 | 05:04 PM
Old_School's Avatar
Old_School
Seriously? not arguing or anything but, i never seen a 98 or a 99 with a 231 (atleast in my area)... Matt's is the first that i seen. Now i have never seen a 2000 or a ram with a 242 and of course the 233 and 244's came post 2001.
Old Jun 2, 2014 | 05:07 PM
Old_School's Avatar
Old_School
Sorry it worked out that way i really was hoping it turn out the way it did for me... Sometime on Wednesday ill be doing a junkyard run and ill have time to look through my spare parts and ill see if i can find an extra switch. If i come across one you can have it.
