Tranny lines to cooler ?
Old Oct 8, 2014 | 09:53 AM
dan_frailey's Avatar
dan_frailey
Default Tranny lines to cooler ?
Hello guys, I was wondering if there was an easy way to get to the transmission cooler lines. I see they disappear into the front toward the radiator. But I can't squeeze my head up in there to see any fittings. The one has a leaking for ever. Do I need any special tools? Oh, sorry, 2002 durango 4.7. Thanks for any advice.
Old Oct 9, 2014 | 01:53 PM
diamondgrip's Avatar
diamondgrip
Try removing your upper shroud to expose the passenger side connections to the radiator. If you have an external tranny cooler then one line will go to your radiator a separate line will run between the other radiator connection (upper) to your external cooler and then the final line will run from the bottom of your external cooler.
You don't need any special tools to remove the connections to your radiator. There are some o-rings used in those connectors that might need replacing. You can safely remove the connections without loosing too much fluid so long as your D is off. In the past i have plugged those connections with some cork stoppers during a radiator replacement.
Old Oct 11, 2014 | 09:53 PM
dan_frailey
Default Confused
Thank you for the advice. I was wondering what is meant by the shroud? The other problem is that I don't even see a cooler any where. But two lines (one very leaky) go up into coolant rad area. I am still confused, I don't understand why it is so hard to find specific info on this type of service in any manuals. Thanks for the help and any detailed advice, I'm just not getting it.
Old Oct 12, 2014 | 03:00 AM
dxloat's Avatar
dxloat
The transmission cooling lines terminate via flare nut at either the trans cooler inside the coolant radiator or a separate radiator just for trans mounted in front of the coolant radiator in the case of Durango's with the tow package. The shroud is the plastic cowling around the coolant radiator that directs the airflow from the fan through the radiator.
Old Oct 12, 2014 | 03:04 AM
dxloat's Avatar
dxloat
You might also try youtube for a video of changing the radiator, which would probably show you where the flare nuts will be found as they would have to be disconnected to change the radiator.
Old Oct 12, 2014 | 09:04 AM
dan_frailey
Default Thanks
So you are saying that the trans fluid runs into the engine coolant radiator. wow I would have never thought that such of thing was done. Thank you, that bit of information was a huge roadblock in my research...Thank you very much for your insight ! ! ! dxloat. Dan
Old Oct 13, 2014 | 08:18 AM
brandofamily's Avatar
brandofamily
There is a smaller trans cooler radiator built into the inside of the engine radiator. Pretty standard set up.
Old Oct 13, 2014 | 05:19 PM
hydrashocker's Avatar
hydrashocker
Inside of a automatic transmission equipped vehicle radiator there is a sectioned off portion for transmission oil cooling. It also helps to warm the transmission fluid when it is cold outside because of the heat the engine puts through.
If you have a tow package then there should be a secondary small oil cooler that the oil would flow thorough for extra aid in cooling after it is cooled in the radiator. Regardless the fluid gets pushed through and back to the transmission.
