ABS sensor broke off!!!
Old 03-01-2015, 01:04 PM
supdupsamy's Avatar
supdupsamy
supdupsamy is offline
Default ABS sensor broke off!!!
I was trying to replace the ABS sensor and when I went to twist it to release the seal it broke off at the surface. Does anyone have any ideas on how to get it out of there without opening the diff cover or is it even possible to get it out of there even with pulling the diff cover? BTW it is a 1998 Dodge Durango, SLT, 5.2L, 4x4.
Thanks,
Kris
Old 03-01-2015, 03:27 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
if it where me i would just open the diff and knock it through at this point,
however i have heard of people having luck drilling and threading a bolt into it to hae something to pull on but ymmv
Old 03-01-2015, 06:21 PM
dxloat's Avatar
dxloat
dxloat is offline
It really only takes a few minutes to open up the diff. I wouldn't screw around drilling and crap that will take much longer as well as possibly contaminate the diff fluid anyway making you have to open it and refill it.
Old 03-03-2015, 10:48 AM
Compactc9's Avatar
Compactc9
Compactc9 is offline
And it won't hurt to change the diff. fluid either, just make sure you have the friction modifier if you have an LSD. You'll also want to have some sealant to re-seal the cover. personally this is the rout I'd take, much simpler.
Old 03-27-2015, 12:44 AM
supdupsamy's Avatar
supdupsamy
How can I tell if I have an LSD? Pretty sure I don't but want to be sure
Quick Reply: ABS sensor broke off!!!
