Just got a 2000 Durango SLT at Auction
Old Apr 3, 2015 | 11:04 AM
  #21
mortonarts's Avatar
mortonarts
Well, Now the lights are fixed. The steering with the second power steering pump from the junk yard is stiff still but a bit better. May need to bleed it. Pretty much it is a brake job away from being done.
Old Apr 3, 2015 | 01:34 PM
  #22
mortonarts's Avatar
mortonarts
Well, I had the Durango's front end up on Jack stands this morning. I bleed the Steering system with it off and went from stop to stop 40 times. That was a bit of a work out. It seems to steer a bit better now. If this doesn't do it I will try replacing the tensioner in it next to see if the belt is just too loose. I also took car of some cosmetic stuff on it. Cleaning and getting corrosion off the engine and sewing up a small hole in the cloth of the seat.
