Flooding and Misfire
Old May 20, 2015 | 11:17 AM
FlamezBro's Avatar
FlamezBro
Default Flooding and Misfire
I am having issues diagnosing this problem. It's a 99 Durango w/ 5.9L and it is misfiring and flooding really bad. I've used half a tank of gas in 30 miles. I have changed everything spark related except the coil. The only sensor I haven't changed is the tps, iac, and temp sensor. Any ideas as to what might be causing this problem?
Old May 20, 2015 | 11:27 AM
dxloat's Avatar
dxloat
Is the service engine light on? If so get the codes for us.
Old May 20, 2015 | 11:32 AM
FlamezBro's Avatar
FlamezBro
I'm not sure what the problem code is for it at the moment but it was throwing a code for the o2 sensors.
Old May 20, 2015 | 11:47 AM
Get the codes read if the CEL is on, then fix those issues. The code will tell you whats wrong. You also did not mention if you have done a full tune up (plugs, wires). Might add that to the list after you get the CEL corrected.
Old May 20, 2015 | 11:54 AM
FlamezBro's Avatar
FlamezBro
Jkeaton, if you will notice in the last two posts it says I changed everything spark related, aka tune up. It also says that I have read the codes from the cel and it says o2 sensors. Thanks for your input though.
Just to clarify I have done a full tune up including cap and rotor.
Old May 20, 2015 | 12:03 PM
My apologies for not fully understanding. Good luck.
Old May 20, 2015 | 02:11 PM
FlamezBro's Avatar
FlamezBro
As of right now there is no CEL or problem codes. But, still having the same issue.
Old May 20, 2015 | 03:26 PM
dxloat's Avatar
dxloat
Did you replace the O2 sensors or just reset the code? Bad O2 sensors will destroy gas mileage. I had a cavalier that cut its gas mileage in half from bad O2 sensors.
Old May 20, 2015 | 03:29 PM
FlamezBro's Avatar
FlamezBro
Replaced them. Still having same issue though. Still no CEL.
