99 5.9 durango
Old Jul 23, 2015 | 10:22 AM
Monsterrango's Avatar
Monsterrango
Default 99 5.9 durango
Well I bought this yesterday gave the guy $2000 for it odometer shows 99654 miles has 37 under it shows its getting 5.4 mpgs any suggestions on how to improve?
Old Jul 23, 2015 | 03:50 PM
Wow....first, how are you checking the mileage? If its from some overhead MPG indicator, throw that out the window and hand calculate to get true mileage. Second, those tires are killing your mileage no matter what so thats something you can change to show an immediate improvement. Along with a full tune up, fluid change, check the brakes to make sure they are not dragging, and a light right foot. Fix the plenum, make sure the cat is not clogged and the O2 sensors are good.
Moved to the correct section. Welcome to the forum.
Old Jul 23, 2015 | 04:15 PM
dxloat's Avatar
dxloat
Unless your doing a bunch of off road I would sell the tires and get some stock size ones, it will be easier on your front suspension to. Our Durangos are terrible for mpg but 5.4 sounds like there's a hole in the tank. If your using the on board computer to tell mpg those tires are almost certainly messin with the calculations and speedo.
Old Jul 24, 2015 | 08:27 AM
Yeah, I was going to add also, if you are using an onboard MPG indicator, it's probably way off due to the tire size.
Old Jul 24, 2015 | 10:35 AM
Monsterrango
Yeah I go off road a lot it's not my everyday I also have a Dakota club cab v6 and yes I was going by the computer on the headliner didn't know how accurate those were.. Would full synthetic oil and Trans fluid make better mpgs and maybe a cold air intake
Old Jul 24, 2015 | 11:30 AM
Not much difference at all.
Old Jul 24, 2015 | 11:33 AM
Monsterrango
Ok well it was sitting at the guys house for a year when I got it had a full tank I'm just gonna drain the gas plugs wires air filter oil change.. Is there any sensors I should consider cleaning? and how do you guys feel about Lucas fuel treatment to clean injectors?
Old Jul 24, 2015 | 12:29 PM
I use Lucas fuel injector cleaner about once every 6 months. I have no idea if it does anything or not. Thats about the only "snake oil" engine or fuel treatment I use. I've heard seafoam does a good job at cleaning things up. Never used it personally.
Old Jul 24, 2015 | 12:31 PM
Monsterrango
Well I ran the Lucas through my Dakota when it was sluggish and it peped up but anyways thanks to all for the help
Old Jul 24, 2015 | 12:34 PM
I've watched some videos on you tube where people use the brake booster vacuum hose to suck seafoam into the intake. Supposedly cleans out carbon build up. But, it produces tons of smoke. Plus I dont like the idea of intentionally sucking a liquid into the cylinders....
