2000 Durango 4.7l error code p1391
Old Feb 15, 2018 | 02:51 PM
RJ186's Avatar
RJ186
I know this is 3yrs old but did you ever fix this???
Originally Posted by MoparNut87
Check grounds all good and even replaced tenisoners for the timing chain. Still have the p1391.
Old Feb 15, 2018 | 09:35 PM
Did you replace your cam sensor? Was it a genuine mopar part?
Old Feb 15, 2018 | 09:44 PM
RJ186's Avatar
RJ186
Yes and yes
Old Feb 17, 2018 | 12:09 PM
Time to go over the wiring thoroughly.
Old Feb 17, 2018 | 12:14 PM
RJ186's Avatar
RJ186
I think its a broken flex plate. I posted a video of the noise on youtube, i cant figure out how to put it on here tho for confirmation...
I posted it under Please help! 01 durango 4.7
Old Nov 28, 2022 | 07:01 PM
daddydaff's Avatar
daddydaff
I am completely baffled by this at the moment, rebuilt the 4.7l engine in my fiancé's Durango after much fighting back and forth with error codes, a new pcm, new crankshaft, all new sensors, a new wiring harness, new battery, new coil packs, spark plugs, new timing chain/ guides/ tenisoners, and re-timing it about 30 times. I am at my wits end. She just will not start, and the only error code that is showing up now is the p1391. Anyone have any idea why this might be happening? Got her to start a few times with starting fluid, very eratic/rough idle, but will not stay running with out feathering the throttle. Please help!
hay buddy it’s your alarm love and unlock your drivers door and your tailgate then it will start for you
Old Nov 28, 2022 | 08:44 PM
Almost five years later, I would hope he got this sorted quite some time ago.
Old Jun 22, 2024 | 12:19 AM
ProblemSolver101's Avatar
ProblemSolver101
I am getting good fuel pressure, can it still be the fuel filter?
oh Yeah, you can pressure the lines but still be starving for fuel.. make sure the filter isn't on back words as well
Old Oct 30, 2025 | 02:50 PM
Themechanic420's Avatar
Themechanic420
I know depending on years the reluctor wheel changes and the teeth count are widely different throws off the crank sensor and will just crank won't start.
Old Oct 30, 2025 | 06:19 PM
Please note this thread is 7 years old.......
