4.7 power steering flow conrtol valve/spring
Old Aug 26, 2015 | 06:05 PM
Mikel8's Avatar
Mikel8
Default 4.7 power steering flow conrtol valve/spring
I've searched high and low for my issue with my 2001 durango 4.7 power steering pump, and nothing. As i was removing the pump for a rebuild I didnt notice that when I removed the high pressure hose from underneath the car that the pressure union came along with it. So as I was removing the pump from the engine I heard something fall and as I look below there was the flow control valve and spring laying on the floor, now I dont know in which order they go. the instructions on the rebuild kit sounds like its talking about the 5.9 pump which looks nothing like mine. the instructions only say "Insert flow control valve spring and valve in pressure port. Valve is installed hex end down."
if I had to pick i would say its the second picture.
2001 durango 4.7 power steering pump flow control valve/spring?
2001 durango 4.7 power steering pump spring/flow control valve?
Any help on this will save me from the big freakin headache I already have
thanks in advance
Old Sep 2, 2015 | 05:28 PM
Mikel8's Avatar
Mikel8
*update* for those who may have the same issue
after some trail and error it turns out its the first picture
first you drop in the spring then goes the valve closed off with the pressure union.
