99 Durango Trouble
I have a 99 durango, 5.2L. V8 SLT It runs fine for a little while then it stalls out, the gauges all go dead except the rpms. the check engine light comes on for a split sec and goes off. "No Bus" also comes up on the odometer. If I let it sit for a while, it will fire right back up like nothing happened and it will do the same thing again. Please HELP ! Thanks
OK. so I had the PCM replaced check the plugs. My truck will drive smoothly and just stall out. The no bus sign no longer appears on the odometer reader. It will immediately start back up but I'm terrified when it shuts off. I travel with my children a lot. Do you have any other suggestions on things I need to check now? Thanks
Multiple post! You should keep it to one post so everybody knows the full story.
https://dodgeforum.com/forum/1st-gen...-stalling.html
Did you check for codes? When does it shut off?
Trending Topics
Its a 99 Durango engine size is 5.2 V/8 engine with 202480 miles. It mostly shuts off when I'm sitting idle at a light or sitting in traffic. Prior to to me changing th PCM, it would shut-off while driving. My mechanic has checked all he can check and can't seem to find the issue. He checked for codes but wasn't getting any.Any suggestions? Thank you
