Several Problems with Dodge Durango 5.9l R/T
Old Feb 23, 2016 | 10:36 PM
JPayne's Avatar
JPayne
Default Several Problems with Dodge Durango 5.9l R/T
I have a 2001 Dodge Durango with approximately 180,000 miles. Some lights on the instrument panel don't work, High beams don't stay on, buttons on the stereo don't work, buttons on the steering wheel don't work, heated seats don't work, cruise control and horn don't work, as well as the abs and brake light warnings are on. What is the problem with it?
Old Feb 23, 2016 | 10:57 PM
Did you just buy it? Might want to read this on troubleshooting.
https://dodgeforum.com/forum/1st-gen...d-testing.html
Old Feb 23, 2016 | 10:59 PM
JPayne's Avatar
JPayne
I bought it last year, and so far ive replace fuel pump, filter, lower ball joints, cv axles, shock/struts, and spark plugs. If any of that is useful.
Old Feb 23, 2016 | 11:02 PM
So did these problems just start or has it been that way since day one?
Old Feb 23, 2016 | 11:04 PM
JPayne's Avatar
JPayne
Cruise control, airbag light and horn all happened in the last few month. Everything else was like that when I bought it.
Old Feb 25, 2016 | 07:01 AM
that_guy's Avatar
that_guy
Cruise, airbag, horn, and steering wheel buttons sound like a clockspring issue. High beam is probably an issue with the turn signal switch/stalk assembly.
Old Feb 25, 2016 | 07:46 AM
I would say a clock spring issue and a multi-function switch issue.
Old Mar 1, 2016 | 04:04 PM
JPayne's Avatar
JPayne
Well I just replaced distributor Cap n Rotor, as well as spark plugs n wires. I am completely going through timing. Reprogramming the PCM and replacing the Multi function Switch, and Clock spring. Ill Keep you guys posted
