Cuts out
Old Mar 13, 2016 | 04:44 PM
mrbubblemaker's Avatar
mrbubblemaker
Default Cuts out
Hey all!! 2000 Durango 5.9l, 4x4, 200,000 miles, Tranny lost reverse many miles ago... Here's the problem: truck will periodically cut out on highway but will not die, in city driving the truck will die and won't start up again for awhile.. I've noticed that the fuel gauge and temp gauge will also be off while the truck is off. I've replaced coil and the coil pickup that's in the distributor.. What's going on with this truck?
Old Mar 13, 2016 | 07:32 PM
Check engine light on?
Old Mar 13, 2016 | 07:42 PM
mrbubblemaker
Yes. It's been on for a long time. Code says bad tranny..
Old Mar 13, 2016 | 08:46 PM
Moparite's Avatar
Moparite
Crank sensors can go bad, Did you have it checked recently? It may have added a code.
Old Mar 15, 2016 | 06:20 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
so the truck shuts off when the engine bay heats up, and wont restart until it cools down?
if that sounds about right then id be suspecting that your PCM is bad, its overheating and shutting down until it cools off again, recheck the CEL and see if any new codes have popped up
Old Mar 15, 2016 | 05:25 PM
that_guy's Avatar
that_guy
A bad crank sensor can also act goofy when hot. Although the gauges dropping off when it's off sounds like a pcm/bus issue to me.
Old Mar 16, 2016 | 10:54 PM
mrbubblemaker
that's what I am thinking also.. My speedometer is also dead but every once in a while it comes on
