steering wheel
Old Mar 31, 2016 | 10:17 AM
dodgedakotaslt's Avatar
dodgedakotaslt
Default steering wheel
hey there I need help figuring out why I still have play in the steering wheel after I just replaced the gear box, steering shaft, ball joints, tie rods, and both pitman/idler arms and just had it aligned also
Derrick
Old Mar 31, 2016 | 10:41 PM
JeeperDon's Avatar
JeeperDon
What did the alignment guy say when you mentioned the excessive play to him?
Old Apr 1, 2016 | 02:13 AM
primem's Avatar
primem
should be easy to check with a helper and performing a dry park check. if all the components are new...is the play backlash in the new steering box?
Old Apr 1, 2016 | 01:41 PM
dodgedakotaslt
is there an adjustment to remove the basklash from the box?
Old Apr 4, 2016 | 08:23 PM
primem's Avatar
primem
most do...I never worked on your model year.
the ones I have done have a lock nut which you loosen, then torque the adjusting nut to a specific torque and reset the lock nut. the steering must be centered in the high point before starting....high point adjustment is what you are setting if you want to google it.
do a dry park check to isolate the play before you do anything. Most new boxes are set up correctly.
