2002 no power going to evap solenoid.
Old Feb 10, 2017 | 04:14 PM
Jayhezie@yahoo.com's Avatar
Jayhezie@yahoo.com
Default 2002 no power going to evap solenoid.
Vehicle will die if lines are hooked up to solenoid.
Throwing code p0499.
Tested solenoid, works fine.
All fuses etc appear good.
Can not figure out why no power going to the solenoid. Also if I bypass solenoid and run directly to throttle body it dies out as well. Figuring something electrical there as well on same circuit not working.
Any suggestions or electrical diagrams?
2002 durango. 4.7L
Thanks. Jay
Old Feb 10, 2017 | 05:19 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Make sure your CANISTER and VACUUM hoses are in the right spot.(your purge valve is upside down) If I had a nickel..............
Old Feb 10, 2017 | 05:22 PM
Jayhezie@yahoo.com
Yes got that all figured out. The problem is no power to the solenoid.
Old Feb 10, 2017 | 05:39 PM
TNtech's Avatar
TNtech
How many connectors does your PCM have. And are they square or rectangle. It matters in the Diagram.
Old Feb 10, 2017 | 05:52 PM
Jayhezie@yahoo.com
Looks like 4 slightly more rectangle then square.
4 rows of pins in the harness I unplugged
Old Feb 10, 2017 | 05:59 PM
TNtech's Avatar
TNtech
If there are 4, it's NGC. That's the newer one. Here you go.
Old Feb 10, 2017 | 07:50 PM
Jayhezie@yahoo.com
Home now but will check with that on Monday and hopefully figure this out.
Thank you
Old Feb 17, 2017 | 10:49 AM
Jayhezie@yahoo.com
Default Problem fixed. Thnx
Thank you for the help
