Power window problems
Please help. Passenger side window will go down but not up. Replaced the motor and still nothing. I can hear the motor trying when I hit the window button down and nothing with the up. I have a power tester and there is power going to the down wire but nothing to the up wire. Tried new switches in the passenger side door and still not working. Checked the wires and none are damaged. Just no power going to the up part of the switch.
<dad_mode>
Odd you chose to buy a new motor without know if it was the motor or not. Throwing new parts at a problem is never the best approach.
</dad_mode>
All power for the windows goes to the driver door. The driver door switches control all the windows. The output feeds from the driver switch, whether being pressed or not, is what feeds the other three doors. It's possible for the driver door switch to be the problem with any window.
</dad_mode>
The motor works. Like I said the replacement one was up when I got it so had to hook it up before installing it in the door to put it down and it went down but not back up. I used a light tester to test the wires and the wire that controls down has power but the wire that controls up does not..
