2000 durango p0204 and p0304
Old Aug 25, 2017 | 06:55 AM
Tony Stewart Sr.'s Avatar
Tony Stewart Sr.
Default 2000 durango p0204 and p0304
2000 dodge durango p0204 and p0304 what should I check. I have a 2000 dodge durango 4.7 and these codes have been on for about 2 weeks. Syptoms is cel and sluggish throttle response .Already switched #4 coil with #6 coil and still same code so is this bad wiring or bad pcm and what tests should I try with multimeter or test light.
Old Aug 25, 2017 | 09:33 AM
https://www.obd-codes.com/p0204
https://www.obd-codes.com/p0304
Old Aug 26, 2017 | 03:11 PM
You are getting injector codes. Need to swap 4 and 6 injectors, and see if the misfire moves.
