durango no start
Old Jan 3, 2018 | 03:26 PM
Durangoriggs's Avatar
Durangoriggs
Reach up on top of the gas tank, and unplug the connector for the pump module. Need to consult a wiring diagram, and see which two wires are for the pump itself...... put a meter across those two wires, and have friend turn the ignition on. See if you get 12 volts across the wires.
i have a question the fuse box with the fuel relay a/c clutch an starter , etax relays are all loose .. you can wiggle them .. they are auppose to be snug tight right
Old Jan 3, 2018 | 03:32 PM
You would think so..... but, so long as they make good electrical contact, that's all ya really need.
Old Jan 12, 2018 | 01:57 PM
Durangoriggs
Default fuses an relays
when i turn key on i have power to my fuel relay but the fuel fuse does not have power going to it .. could that mean bad relay or short ?
Old Jan 12, 2018 | 05:48 PM
that_guy's Avatar
that_guy
Why not swap it with another relay to rule that out?
Old Jan 15, 2018 | 04:13 PM
BBICLBIC's Avatar
BBICLBIC
Question 04 Durango wont turn over
Hello .o4 Durango wont turn over .I have new battery got 12.5 volts .I been putting a new Boss 2 pin Stereo in it And a SWC interface system in her .everything going ok . I been starting of and on last couple days no issues .This Morning turn the key nothing no turn over . I got all outside lights ,I got interior Lights ,New Stereo works ,.. But no lights on the dash lights and wont turn over ??? please help I am stumped .Thanks She also has the 5.7 Hemi .
