overheating issues
Old Jan 30, 2018 | 11:33 PM
nathan1009's Avatar
nathan1009
Default overheating issues
i have a 2000 durango with almost 200k miles and its overheating. replaced thermostat and electric fan and its still over heating. I don't know what to do next. I have the 5.2 L only 2wd. thermostat was non existent since I bought it a year ago. I've never had this problem before and I live in florida with this heat and i don't know why it happened now when its cooler out but not at all last summer. I had just found this out when I went to put a new one in it. water pump seems to be pumping cause its fine at idle, but soon as I start driving it over heats
Old Jan 31, 2018 | 06:41 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
are you loosing coolant? is the radiator partially clogged? (you can check this with a IR thermometer, or a FLIR camera if you have access to one)
Old Jan 31, 2018 | 01:12 PM
nathan1009's Avatar
nathan1009
not losing any coolant.. the radiator being stopped up I don't know. and I don't have access to either of those
Old Jan 31, 2018 | 03:09 PM
You can pick up the IR thermometer from the parts store pretty cheap...... the camera, on the other hand, is likely terribly expensive.
Old Jan 31, 2018 | 08:45 PM
nathan1009's Avatar
nathan1009
i don't know if this makes a difference or not but when i put water straight into the block where the thermostat goes, the engine wont over heat.. it'll get to 240 but it will go back down to like 130 long as i keep moving at a good pace
Old Jan 31, 2018 | 09:07 PM
An air pocket in the cooling system will do that......
Old Jan 31, 2018 | 09:21 PM
noman's Avatar
noman
My guess would be air pocket also. You have the same engine I do. I never had problems with a air pocket. What do you mean by the thermostat was non existent? Like it wasn’t there?
Old Feb 1, 2018 | 06:27 AM
shrpshtr325
THE ULTI-MOD
well if your not loosing coolant how is there any room in the cooling system for you to put water in there? that should remain FULL unless you have a leak somewhere.
if you are able to add coolant here without removing any, and have no external leaks you have an internal leak, most likely a headgasket.
