My P1391 issue - Can anyone help
Old Feb 7, 2018 | 10:06 AM
lcattin's Avatar
lcattin
Default My P1391 issue - Can anyone help
I have searched some of the threads but am still scratching my head.
Maybe someone can help.
I recently aquired a 2001 Dodge Durango 4x4 with a 5.9l with California emissions.
The truck has 212,500 miles on it.
Here is the history of the vehicle as I know it:
Previous owner had a new set of heads installed 5000 miles ago due to cracks in the heads.
He said it run just fine after repair.
He had a complete brake job done on the car and 1000 miles later it quit running with the "no bus" message.
He got another computer somewhere and installed it.
He said that the engine then started up but ran badly like it was starved for fuel and then the "no bus" message after about a minute of running.
He was not mechanically inclined so put it up for sale when I then purchased it.
He had the original computer so I sent it to a place in Illinois that repairs them.
I got it back last Friday and installed it.
The engine started but had a high pitched ticking sound coming from the right front of the engine.
I then installed new cap, rotor and wires and the ticking went away.
The plugs in it look new.
The engine stumbles badly when cold but after a few restarts will finally idle and drive great.
After a short drive it will start missing very bad while driving and eventually throw a P1391 code but idle very well.
While running this way the tach needle is bouncing around.
I changed both the crank and cam sensors with BWD parts from the local parts store with no improvement.
I checked the distibutor timing visually and at TDC the cyl one mark on the cam sensor lines up with the rotor.
Still has the original coil in it.
I am at a loss for now trying to figure out what is.
Anyone have any ideas as to where to go?
Thank you in advance
Old Feb 7, 2018 | 02:00 PM
You want to get your crank sensor, at least, from the dealer. These trucks just aren't real friendly with aftermarket parts in critical locations.... and the crank sensor is right at the top of the list.
Old Feb 8, 2018 | 08:19 PM
lcattin's Avatar
lcattin
Thank you. That was the problem. I put the original crank and cam sensors bask it and the truck started right up and now runs as it should.
I appreciate the help and from now on it's only Dodge parts in critical areas.
Old Feb 9, 2018 | 08:10 AM
Awesome. Glad to hear your back up and runnin'.
