2000 durango wont start
Old Jul 15, 2018 | 01:26 PM
Amandalouisa's Avatar
Amandalouisa
Default 2000 durango wont start
My 4*4 Durango wont start after my serpentine belt broke. I replaced the belt and it sstill wont crank just whines like its not sparking. I put a new battery in and it still wont start. After belt broke in my yard. It cranked back up then. What can I do?
Old Jul 16, 2018 | 07:13 PM
that_guy's Avatar
that_guy
So it won't start after the belt broke, but it also did start after the belt broke? Care to elaborate? What engine? How long has it sat?
Old Jul 16, 2018 | 07:19 PM
Amandalouisa
Default Provlem solved
The truck started immediately after the belt broke but wouldnt start back up after the new belt was put on. My mechanic said that the a/c comoressor had locked and that broke the belt and wouldn't let it start back up. So here's hoping that once thats put on it'll be fine. Thanks so much.
Old Jul 16, 2018 | 07:24 PM
that_guy's Avatar
that_guy
Does it still start with the belt off now?
Old Jul 17, 2018 | 07:31 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you think a locked up a/c cmpressor is the problem get the shorter, non a/c belt and see if it starts with that belt on, if it does then you have your confirmation. alot cheaper than throwing an a/c compressor or clutch at it hoping its the right part.
Old Jul 23, 2018 | 10:28 PM
FlynDodge's Avatar
FlynDodge
Also, just for start testing, you don't need the belt at all. Just leave the belt off and try to start it. The A/C pulley should spin easily by hand without the belt on there.
Old Jul 25, 2018 | 09:13 AM
Dodgevity's Avatar
Dodgevity
If the compressors is "locked", then that should just be the idler clutch assembly. When the AC is off, the pulley should spin free. Once you turn on the AC, the clutch magnetically locks and starts turning the compressor. Replacing the clutch is a lot cheaper than replacing the entire compressor. I replaced mine without removing the compressor lines, so no Freon was lost.
