Jumps at 3200 RPM
Jumps at 3200 RPM
I have a 2003 Durango 4.7 4wd and have had issues with cylinder 5 misfire for the past three years I have replaced coil packs and plugs so many times I have the tools in the glove box along with a plug and coil. A friend of mine had the same issue on a caravan told me to change the Crank Sensor that was his problem.
I changed the crank sensor after having to torch the old one to free it from its home. it was hard to start took three times then when I get to 32-3500 RPM it acts like it hits the rev limiter. I took the positive off the battery and held the key for 30 seconds to reset the PCM but no change. For those that say you just need to drive it I put 600 miles on this weekend.
I got the sensor at AutoZone I think it is a BWD brand.
codes are p0339 and p0305
