engine died 2 miles after oil change no crank now
Old Sep 7, 2018 | 12:19 PM
drose977's Avatar
drose977
Default engine died 2 miles after oil change no crank now
Had my oil changed at "5 minute oil change" and check engine light came on 2 miles later. Noticed ticking noise that was not there before oil change. Engine died as I was turning into my driveway and will not restart. Won't even turn over. Checked dipstick and it is about 3 inches over safe mark. Didn't notice any smoke from tailpipe. Can't drive it back to oil change shop because it won't start.. I have 168K miles on my 1998 5.2L which I bought new. What should I do?
Old Sep 7, 2018 | 01:57 PM
JeeperDon's Avatar
JeeperDon
Originally Posted by drose977
What should I do?
Not a wiseazz answer, but change your own oil. These 'oil change place disaster' stories are way too frequent. What to do now, call the oil place and give them what-for.
Old Sep 7, 2018 | 05:06 PM
So why is the oil over full? Is it *just* oil? Or is their coolant, or gas, mixed in there as well? I would not suggest touching ANYTHING beyond doing investigations at this point. If the oil change place screwed it up, they owe you a motor. (and small claims court will get you one.)
Old Sep 7, 2018 | 07:32 PM
Dodgevity's Avatar
Dodgevity
Three inches over safe? That would mean the oil was extremely overfilled. Pour in enough oil and the oil will reach the crankshaft. The crankshafts whips the oil into a froth. The oil pump is now starved because you're pumping frothy air bubbles instead of liquid, so the effect is the same as if you ran it with little to no oil.
I agree with the change your own oil sentiment. But, if you let someone else do it, at least check it before you leave the place. These places do all kinds of crap. Loose oil filters and bungs, missing oil caps, forgetting to put ANY oil in or overfilling.
Old Sep 7, 2018 | 10:23 PM
primem's Avatar
primem
one option- have it towed to a shop. If the problem is related to the oil change...you have a professional diagnosis to support a claim against the lube shop. Speak to the manager of the lube shop with the results of the diagnosis...if they won't correct it.... Expert opinions go a long way if you have a day in court. Go after then for the damage and any related costs...diagnosis, rentals.
if you used lube shops...at minimum, do an oil change and inspection once a year at a shop that has licensed mechanics....to check suspension and brakes.
Old Sep 9, 2018 | 02:58 AM
drose977's Avatar
drose977
Mystery solved---I called the 5 min. lube place and they sent out their manager who got it to start up again. Seems the engine died possibly due to a loose battery cable not allowing the alternator to charge it completely. When I checked the oil I was on a hill causing an inaccurate reading.... silly me. Once on flat ground oil level was fine. Fired back up with no check engine light but did have a check GAUGES light and saw that my oil gauge was at zero. Probably the oil pressure sensor is bad. Wanted to provide an update and to say how impressed I was that the "Take 5" shop. They are first class for sending someone to my house to get it going, and for no charge.
Old Sep 9, 2018 | 10:14 AM
Alls well that ends well?
Old Sep 9, 2018 | 02:01 PM
b1lk1's Avatar
b1lk1
This is an excellent example of how a polite (but kinda firm) phone call gets a much better response than a lunatic rant.
Glad it is OK!
