Cylinder #2 smoking
Old Oct 12, 2018 | 06:01 PM
Dbeemen93's Avatar
Dbeemen93
Default Cylinder #2 smoking
I don't know why this is happening I have a 2002 dodge Durango 4.7 as I was driving home one day I smelt a bad stinky smell so I pulled over and popped the hood and saw white smoke coming from cylinder #2 so cut it off and started it back up and the smoke was gone until I got home so I popped the hood again and it was ever more smoke. I took out the coil pack and saw that it had burned on one side of it. Can anyone tell me what will cause that to happen
Old Oct 13, 2018 | 08:19 AM
that_guy's Avatar
that_guy
I doubt the issue is on the secondary (12v) side of the coil otherwise you'd have something fried in the computer. My guess is either the coil had some internal short on the primary (plug) side. Check the plug gap and condition of the insulator before replacing the coil.
Old Oct 13, 2018 | 08:43 AM
Dbeemen93's Avatar
Dbeemen93
Default I replaced it
Okay i will take a look at it i just never seen anything like this b4 and every mechanic i had come look at didn't know what was going on
Old Oct 13, 2018 | 11:43 AM
Dbeemen93's Avatar
Dbeemen93
what do you mean the plug gap
Old Oct 13, 2018 | 01:20 PM
that_guy's Avatar
that_guy
exactly that. the plug gap. the distance between the ground and electrode.
Old Oct 13, 2018 | 01:33 PM
Dbeemen93's Avatar
Dbeemen93
on the spark plug rite
Old Oct 13, 2018 | 04:06 PM
Dbeemen93's Avatar
Dbeemen93
so I check it all it is all okay so I went ND brought all new coil packs and spark plugs ND it's still heating up more than the other ones and on top of that the temperature gauge stays in the red I just replaced the thermostat and the thermostat sensor so I truly don't know what is wrong
Old Oct 13, 2018 | 07:46 PM
that_guy's Avatar
that_guy
You shouldn't drive it with the temp near the red. You need to figure out the cooling system issue. Air in the system maybe?
Old Oct 13, 2018 | 08:02 PM
Dbeemen93's Avatar
Dbeemen93
How would i get the air out the system
Old Oct 13, 2018 | 08:20 PM
that_guy's Avatar
that_guy
search around for how to bleed the 4.7. I think there's a bleed screw somewhere to help, but don't know where.
