1999 dodge Durango 5.9 wont heat/no heat
Old Oct 19, 2018 | 08:09 PM
scouter101's Avatar
scouter101
Default 1999 dodge Durango 5.9 wont heat/no heat
hi i'm new here so hears the thing i have a 1999 Durango 5.9 and the motor wont get above 135 when the temp is below 50 but worms up nicely when temp is 50+ with this problem i have 0-little heat when temp is under 50 and excellent heat when temp is 50+. so far i have replaced t-stat back flushed the heater core back flushed the radiator and flushed out the motor as well. am i missing any thing looking for ideas on this thanks
Old Oct 19, 2018 | 08:57 PM
Fan clutch stuck?
Old Oct 19, 2018 | 09:35 PM
scouter101's Avatar
scouter101
fan clutch seems to be working just fine
Old Oct 20, 2018 | 09:09 AM
What brand thermostat. The engine should get up to temp regardless of outdoor temp.
Old Oct 20, 2018 | 11:02 PM
scouter101's Avatar
scouter101
duralast 180 degree
Old Oct 21, 2018 | 09:12 AM
Buy a better thermostat. Stant is good.
Old Oct 21, 2018 | 09:38 AM
Pspklutch's Avatar
Pspklutch
I have a stant 180 and a stant 195. I just put the 195 in until about May when I'll switch back to the 180. I get warm air with the 180. I get hot air with the 195, which is the factory temperature. So it might not hurt to go to one of those.
Old Dec 6, 2018 | 03:03 AM
GreenBayGuru's Avatar
GreenBayGuru
Get your heater core blasted, I had the same problem and this got me back to cookin
Old Dec 10, 2018 | 05:48 PM
that_guy's Avatar
that_guy
Sounds like thermostat.
