ABS and Brake Light on already replaced sensors
Old Dec 22, 2018 | 07:13 PM
George Genovezos's Avatar
George Genovezos
Verify the wiring.
sure. Do you have a diagram and test procedure?
Old Dec 23, 2018 | 09:38 AM
I think there are some PDF versions of the manuals around here somewhere..... wiring diagrams will be in there. (section 8W) Basically, just verify the wires are good. (continuity from one end to the other.)
Old Dec 24, 2018 | 09:09 AM
Jake85's Avatar
Jake85
Default Same problem
I'm having the exact same problem on my 2000 4.7l 4x4, but have not tried to remedy yet. It's not throwing any codes when i plug in OBDII, I'm not quite sure where to start... Thanks.
Old Dec 24, 2018 | 10:17 AM
b1lk1's Avatar
b1lk1
You cannot get codes when using a generic OBD II reader, you need a reader capable of reading ABS codes.
Old Dec 24, 2018 | 12:39 PM
Alex Genovezos's Avatar
Alex Genovezos
I just noticed when I first start the car the speedometer doesn't work till about 20mph however it seems to get better after driving a bit but still seems a little sporadic. Could I have gotten a bad rear wheel speed sensor?
Old Dec 24, 2018 | 06:17 PM
Jake85's Avatar
Jake85
I'll have to get my hands on one of those then. Thank you sir!
Old Dec 25, 2018 | 10:16 AM
Yes.
