ABS and Brake Light on already replaced sensors
Old Dec 20, 2018 | 11:08 PM
Alex Genovezos's Avatar
Alex Genovezos
Default ABS and Brake Light on already replaced sensors
Hey, everyone, I have the common problem of the abs and brake light being on and I have searched through the forums to find what sensors needed replacing and I replaced them. However ones I replaced both the speed sensor and output transmission sensor the problem persist. I also replaced the ABS module with a junkyard one and the problem still persist.
Any advice would help. Thanks in advanced.
Alex
Old Dec 21, 2018 | 09:27 AM
What are you driving? 2 or 4 wheel abs?
Old Dec 21, 2018 | 09:34 AM
Alex Genovezos
Sorry about that. 2000 Durango 2 wheel
Old Dec 21, 2018 | 09:46 AM
Usually, that's a symptom of a failing rear wheel speed sensor.... Usually..... Does your speedometer work right? (it also gets its signal from the rear wheel speed sensor.)
Old Dec 21, 2018 | 11:15 AM
George Genovezos's Avatar
George Genovezos
Speedometer is working properly. We replaced the sensor in the differential and the output sensor in the transmission.
Old Dec 21, 2018 | 11:19 AM
May need to get the codes read, and see what the system is whining about then.
Old Dec 21, 2018 | 12:21 PM
George Genovezos
Code 14 RAM read/write error.
Old Dec 21, 2018 | 06:33 PM
Bad controller.
Old Dec 21, 2018 | 07:19 PM
George Genovezos
Bad controller.
agreed, but replaced it with 2 others off Ebay. One was even "rebuilt".
bad luck?
Old Dec 22, 2018 | 05:52 PM
Verify the wiring.
