Front end grinding
Old Aug 17, 2019 | 03:39 PM
Sarah Amesbury's Avatar
Sarah Amesbury
Default Front end grinding
Ok. So my tie rod end cv axle and bearing hub assembly is replaced first Thing I did was the hub assembly. The grinding noise came back shortly after. Popped off my diff case and filled with fresh gear oil and it stopped for a while then came back. I'm at a loss HELP. Its intermittent which is confusing.driver side.
Old Aug 17, 2019 | 09:14 PM
How do the CV joints look? Are they original still?? Also, what are you driving?
Old Aug 17, 2019 | 10:45 PM
Sarah Amesbury
2002 5.9l durango. Boots were intact. Im thinking my hub assembly was faulty
Old Aug 18, 2019 | 08:33 AM
Oh, a bad part right out of the box???? That never happens......
Did you torque the axle nut to spec? I think its' something truly stupid, like 185 ft/lbs......
Old Aug 18, 2019 | 11:23 AM
Sarah Amesbury
I dont have a long toue wrench but i have a feel for high torque and ive got to be pretty close
Old Aug 18, 2019 | 02:16 PM
That's a pretty critical spec though. That nut, and the axle, are what holds the bearings together. Too much, or not enough, and the bearing life will be shortened dramatically. Should be able to rent a torque wrench from you local parts store.....
Old Aug 18, 2019 | 04:39 PM
Sarah Amesbury
Ok thanx for the info could be my fault for a premature wear
