Vehicle sat for a while. All lines were rusted and shot. So I replaced them. Had 2 blow out. So i just changed them all. Is there a way to check the valves?
See which end isn't getting fluid. (just crack a bleeder open, and have someone step on the pedal.) Once you know that, have someone pump up the brakes, and hold pressure, then, open one of the bleeders on the opposite end. That should shock the valve back into place. Might require a couple shots to get it to move.
