2000 Durango 4.7L Oxygen Sensor Blues
Old Dec 18, 2019 | 07:57 PM
sporta's Avatar
sporta
Default 2000 Durango 4.7L Oxygen Sensor Blues
OK everyone, I need some expert advice....my 2000 Durango with the 4.7l engine is throwing a P0135 after replacing the O2 sensor Bank 1 before the CAT. Does anyone have the definite part number for this blasted thing???? And besides the "Mopar" brand is there another acceptable manufacture for these things? Need to get her smogged before the 22nd of December so time is running out...Also as a test, would it be ok to try and pull one from Pick-N-Pull just to see if it works?
Thanks,
Steve
Old Dec 18, 2019 | 09:17 PM
That's a heater circuit malfunction. I believe the PCM controls a relay, that supplies power to the heater side of the sensor. It expects to see voltage on that when it turns it on..... May be a bad relay, bad fuse, bad wire, or bad sensor. If you already tossed a new one in there, and are getting the same code, time to start tracing wires.
NGK or Denso for O2 sensors. Skip bosch, Dodges don't like 'em.
Old Dec 18, 2019 | 09:38 PM
sporta's Avatar
sporta
I'll check the relay and fuses tomorrow...thanks
Old Dec 20, 2019 | 01:35 AM
sporta's Avatar
sporta
Got tied up with other projects today...adulting sucks but had a question....when I got the alignment done, the shop did a "complimentary check" of Red and reported the battery "failed the load test"....per their nifty little scanner, it said "Replace Battery" ... Volts were measured at 12.54v, CCA was 615 with a rating of 810 CCA. could the battery be contributing to the sensor issues? I will be going over the relay and fuses tomorrow...cleared my schedule and am going to MAKE TIME to go over her...Need to get her smogged ASAP.
Thanks in advance
Steve
Old Dec 20, 2019 | 10:36 AM
It's possible, but, if you aren't experiencing any other electrical 'oddities', likely not the cause. Still, it's winter, at least, it is here..... So, wouldn't hurt to replace the battery anyway.
