46re transmissions.
Old Jan 14, 2020 | 12:00 PM
Stevedillon's Avatar
Stevedillon
Default 46re transmissions.
Ok. My question is about the 46re trans. I have a good one from an 02 that i want to swap into a 00 the question is what i need to do with to 02 trans before i put it into the 00 the 02 is electric button 4x4 the 00 is a manual on the floor 4x4. Im needing to know whats involved in the swap as far as connecting and and thing that needs switched for the o2 46re to go into the 00. Thanks before hand.
Old Jan 14, 2020 | 06:47 PM
Keep your original transfer case, and it should be a direct swap.
Old Jan 14, 2020 | 07:41 PM
that_guy's Avatar
that_guy
The range indicator probably needs swapped over on the trans.
Old Jan 14, 2020 | 10:07 PM
Stevedillon
Thanks both of you.
