After market radio
Old Feb 2, 2020 | 11:14 PM
HRMN50's Avatar
HRMN50
Default After market radio
I知 looking to replace stock head unit with a digital radio and I found one that will work with my 1st gen. I知 wondering if anyone has used the dual XDVD176BT and had any problems with it. Thanks
File Type: html
Old Feb 4, 2020 | 07:09 PM
sporta's Avatar
sporta
Haven't tried the head unit you posted but from looking at it, won't that block most of your heating controls/vents with the screen up? I've been toying with the idea of replacing the head unit in my Red Durango with this:
https://www.amazon.com/dp/B07QR5P1ZD/?coliid=I3UI0WS1YFX29I&colid=3BGLKHWHPMB1&psc=1&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B07QR5P1ZD/?coliid=I3UI0WS1YFX29I&colid=3BGLKHWHPMB1&psc=1&ref_=lv_ov_lig_dp_it
. Think I am going to try it in our Pontiac Grand Am first and see just how good it is..Another suggestion is that Crutchfield is selling a Double Din Kit for the Durango's...so that might be an option for you as well... https://www.crutchfield.com/p_120956542/Metra-95-6542-Dash-Kit-Black.html . Keep us posted to what you do decide to use...would like to see what you go with and any other suggestions out there.
Steve
Old Feb 4, 2020 | 07:12 PM
HRMN50's Avatar
HRMN50
Yeah it would block the vents but I pretty much run the defroster the whole time because not a fan of the hot air blowing in my face. After some measurements I don稚 think it値l fit. The little lip above the vents would hit on the 7in screen
Old Mar 5, 2020 | 05:21 AM
klimjo's Avatar
klimjo
Hi I have 2007 ford fusion I would like to upgrade my stereo to Bluetooth gps and backup is there any stereo that you could recommend that will work in my car thank you.
Kodi Lucky Patcher nox
Old Mar 5, 2020 | 08:50 AM
This is a dodge forum. We don't have a clue about your ford.
Old Mar 5, 2020 | 01:47 PM
sporta's Avatar
sporta
HeyYou is correct, but I would suggest going to www.crutchfield.com and putting your car info in there...they should be able to tell you what would fit with no issue...good luck.
