High voltage codes
Old Mar 12, 2020 | 01:21 PM
tfj3038's Avatar
tfj3038
Default High voltage codes
So I recently replaced the valve covers on my 03' durango with a 4.7. After I hooked everything back up, my check engine light came on and was spitting a p0113 (IAT Sensor Circuit High Input Problem), p0118 (ECT Sensor Circuit has higher than normal voltage), and a p0108 (Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor -high input). It had non of these codes when starting the project, but now that i'm done, they pop up. I'm thinking because they are all high voltage related its a grounding wire problem, But i cant seem to find any schematics online to help. Anyone know what the problem could be or where I could find the schematics?
Old Mar 12, 2020 | 03:55 PM
More likely there is a pinched wire somewhere, and you are feeding 12 volts to sensors that only want 5........ Test a couple of the sensors in question with a meter. See what kind of voltage you see on the assorted pins.
Old Mar 12, 2020 | 08:22 PM
primem's Avatar
primem
high voltage codes set when the circuit is open...the circuit is reading the potential voltage of an open circuit. check for connectors not seated or not plugged in
