mistery coolant leak
Hi all,
6 months ago my water pump went. I replaced the pump, the bypass hoses and did the job right (all new parts)
Last week I went on a long trip and started overheating.
Got her home and pressurized the system. I have a 20' + driveway and I can see coollant dropping off the crank. It's running from the passenger side of the block near the crank but can't see anything else.
ANy idea where it might be coming from? I dont' want to pull the pump if its not a common issue.
Thanks
Thanks
What engine? Set your phone to snap pics by voice and snap a bunch of pics of the area while it's leaking. That sometimes works when you can't stick your head in there. You might have to pull the fan shroud, belt, etc so you can take a good look.
I have the 4.7L, so hard for me to tell you. Remove whatever you can that's in the way, so you can get a good look at it as you pressurize it.
Check for green stains at the weep hole. What brand pump did you put on? Warranty? You might have gotten a bad pump. Especially if it's a rebuilt unit.
Trending Topics
Hi all,
Thanks
Thanks
Steve
