Drain Plug Nut Inside Oil Pan Broken - Fix Recommendation?
Old Mar 25, 2020 | 03:20 PM
fcastro's Avatar
fcastro
Default Drain Plug Nut Inside Oil Pan Broken - Fix Recommendation?
Hi all, I have a 5.9 engine on a stand. It didn't have the oem drain plug, after taking the oil pan off, it turns out they had installed some plug fix. I was going to change it because it was leaking slowly. So when I get to the inside of the pan, I see the plug nut, where the oil plugs goes into, just floating at the bottom of the pan. Apparently the original owner or a shop broke the nut off the pan, probably by over tightening.
Does anyon
e know of any plugs I could install to fix the problem? I can't seem to find anything that would screw from the inside with a but to the outside for example.
Old Mar 25, 2020 | 08:45 PM
Can you just clean up the spot where the nut is supposed to be, get a new drain plug (bolt), tighten it down, then weld the nut back to the oil pan?
Old Mar 25, 2020 | 10:06 PM
fcastro's Avatar
fcastro
I just flux welded the nut on the inside and outside, now I have to test my welding work. Doesn't look pretty especially on the outside part. I ground down the weld but I'm unsure if the screw is going to leak oil.
Old Mar 26, 2020 | 06:59 AM
Dodgevity's Avatar
Dodgevity
Buy another pan. You have the engine out so it should be an easy swap.
Old Mar 29, 2020 | 11:53 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
this would be my recommendation too, why waste the time when replacing the pan is such an easy fix for you.
