Transfer case
Old Jun 7, 2020 | 05:48 PM
Ddustin's Avatar
Ddustin
Default Transfer case
I'm looking to rebuild my leaking transfer case on my 98 Durango. The site lists 2 different types, one with a 16mm input bearing and 62mm OD rear main bearing and the other with a 24mm input bearing.
How do I know which one to get.
Also are there any upgrade or anything available while I'm down there?
Old Jun 8, 2020 | 09:06 AM
that_guy's Avatar
that_guy
You need to identify the transfer case you have first, then get the correct parts for the transfer case you have. You'll have either an nv231 (only part time 4wd) or a nv242 (part and full time 4wd).
Old Jun 8, 2020 | 12:01 PM
Ddustin's Avatar
Ddustin
Nv242
Old Jun 8, 2020 | 12:11 PM
There might be a BOM (bill of materials) number on the t-case, and you should be able to look up which bearing it has with that. Or, disassemble it, and have a look.
Old Jun 8, 2020 | 12:43 PM
Ddustin's Avatar
Ddustin
How would I go about looking it up? The transmission could take 3 weeks so that's too long for me to take it apart now.
Old Jun 8, 2020 | 03:26 PM
Go no New Venture Gears' website. They should have that option somewhere.
Old Jun 8, 2020 | 07:27 PM
that_guy's Avatar
that_guy
If it helps, the durangos technically use a 242D. I believe this is different than the jeep version, possibly stronger.
Old Jun 8, 2020 | 09:22 PM
Ddustin's Avatar
Ddustin
I read this in a jeep forum about the NV242. Is this accurate?
