Durango transfer case
Old Aug 30, 2020 | 05:10 PM
Zane007's Avatar
Zane007
Default Durango transfer case
I have a 2003 durango slt, recently I was off-road and the truck stopped driving in awd. It would shudder and shake and make grinding noises when I tried to drive forward. I was able to drive it home in 4 hi and think this is an issue with a transfer case. Is that correct or could it be something else? If so I know someone selling a 2003 v6 dakota transfer case for a reasonable price, would this work on my durango? Thanks for any help!
Old Aug 30, 2020 | 08:26 PM
What t-case do you have in yours? I don't think the dakota t-case will be the same, as I don't believe they were ever offered with AWD...... but, I've been wrong before.
Old Sep 2, 2020 | 04:20 PM
Zane007's Avatar
Zane007
I believe the t-case in my truck is an nv244 and the one from the dak is a 233d
Old Sep 2, 2020 | 06:25 PM
According to this thread, its a direct bolt in. Shift pattern will be different though, obviously. (no full time 4wd on the NV233 case.)
Old Sep 3, 2020 | 08:23 AM
00t444e's Avatar
00t444e
Make sure both of your driveshafts are still connected.
Old Sep 3, 2020 | 12:04 PM
Zane007's Avatar
Zane007
I have done more research and it looks like it will bolt in, but I contacted a Dodge dealer near me and they told me I would need to get a pcm programmed for a 233 to make the swap work.
Old Sep 3, 2020 | 01:45 PM
Yeah, if you have electronic controls, that will likely be an issue.
Old Sep 3, 2020 | 02:13 PM
Zane007's Avatar
Zane007
I do have electronic controls, but I haven't read anything about changing out the pcm in any posts where people swapped from a 233 to a 244. I dont know why it would be any different going the other way around.
Old Sep 3, 2020 | 08:33 PM
Different shift patterns, so, the controller is likely different...... Can try it, and see what happens.....
