Brake bleeding
Old Oct 23, 2020 | 03:10 PM
humasima's Avatar
humasima
Default Brake bleeding
Hi, Newbie here.
I have a 2002 Durango, but the welcome email i got said to Wander on down to the Second Gen Dakota section.
Just a basic brake bleeding question, I replaced my front metal brake lines and tee.
I didn't touch the back lines, but is it possible i have to bleed the back?
I'm bleeding the front, no air left, no leaks anywhere, but the pedal isn't coming up much.
Pads and shoes are only about 1/3 worn, drums and rotors in good shape.
Brakes worked fine prior, it was a preventative replacement. Originals and looked like twigs.
I know the simple answer is to try it, but the back is older and i don't see why i would have to.
Thanks!
Old Oct 24, 2020 | 10:04 AM
I'm an idiot, and can't read.
Moving this to the Durango section.
And yes, when you bleed brakes, always start in the back, regardless of if you opened the system or not. Right rear, Left rear, right front, left front.
Old Oct 24, 2020 | 03:21 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by humasima
Hi, Newbie here.
Thanks!
Any time the system is opened, you need to bleed the entire system. Air bubbles are sneaky and get in even if you're careful. Instead of moving fluid, they collapse and don't move prerssure.
