Help with replacing helicoil in stripped steering knuckle
Old Apr 29, 2021 | 03:10 PM
Overdrive99's Avatar
Overdrive99
Default Help with replacing helicoil in stripped steering knuckle
I just replaced the lower ball joint on drivers side of my 1999 Durango SLT 4X4. When I was about to reattach the brake caliper I noticed there was an old helicoil coming out of the top thread on the steering knuckle. I can’t tighten the mounting pin into it. At first I though about just replacing the whole steering knuckle but then after calling around to junkyards around interior bc, realized it’s harder to find one than I thought. Im back to thinking I should just replace the helicoil and be done with it. I read on here and other forums that there is a repair kit made specifically for this problem but I couldn’t find the exact kit anywhere and wasn’t sure how it would work with taking out the old helicoil and re tapping it to put a new one in. Any advice is appreciated!
Old Apr 29, 2021 | 04:56 PM
It's already tapped to the correct thread for the helicoil, just need to take the old one out, and put the new one in. (with some red locktite..... ) Local parts store should be able to get you the repair kit.....
Old May 30, 2021 | 08:57 PM
volaredon's Avatar
volaredon
I found an actual kit from the helicoil company at a swap meet years ago, and it's even labelled as a spindle thread repair kit for Dakota and Durango. I had to buy it, got it cheap back then, have used it several times and not just on my trucks either. I think I need to get some more helicoils to refill the kit. Comes with the drill, the tap, the helicoil driver and originally like 10 inserts.
