Transmission control module
Old Jul 25, 2021 | 04:11 PM
4.7 Jonesin's Avatar
4.7 Jonesin
Originally Posted by shrpshtr325
to the best of my knowledge the 5.9 does NOT HAVE a separate Transmission control module, thats a 4.7l goodie only.
whoop the 4.7 tcm is not with the pcm. Enlighten me .my trans Mississippi has stopped responding
Old Jul 25, 2021 | 07:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Yes, The powertrain control module (PCM) does also control overdrive on a 44/46RE transmission. The transmission module is partition inside the the PCM body. The RFE transmission does have a controller for the transmission. The NAG1 also had a trans controller for charger and challenger are under the dash. 8speed and 9 speeds are inside the transmissions.
Old Jul 25, 2021 | 08:57 PM
4.7 Jonesin
THank you.my mistake.
Old Jul 25, 2021 | 10:06 PM
jims's Avatar
jims
Default Aren't
Isn't there a fuse for the OD to check first on these or not ?
Old Jul 25, 2021 | 11:19 PM
master tech
There is a fuse and a transmission relay in the PDC/IPC box under the hood. But that doesn't control overdrive.
Old Aug 15, 2021 | 10:43 PM
4.7 Jonesin
Default 4.7 goodie
I wish it was. Goodie
