Top end rebuild advice
Not too long ago, I made a giant mistake and left the radiator cap off of my 2000 dodge durango, with the 4.7. She obviously overheated, and since 4.7's don't like heat, I almost dropped a valve seat. Once I can afford it, I'm sending the heads to "cylinderhead services" in spokane to be rebuilt, I'll be replacing the timing set, and then, obviously, all of the gaskets, new head bolts, and all new fluids. One question I can't seem to find an answer for, is, should I replace the dowel pins? Would it hurt to leave them? Some other questions I have are, should I check anything else? Is dropping the pan necessary? Other than remembering to put the radiator cap on, what kind of preventative maintenance can I do? Is 50/50 an okay mix for coolant where I live? It can get down to negative in the winter, and tends to be over 100 in the summer. Should I test the thermostat? It has a fairly new 180 degree thermostat, should I go lower? Can I go lower? Is there anything I'm not thinking of? I'm babbling at this point, so, as always, I appreciate any help or advice, and thank you so much for your time.
Don't worry about the dowel pins. If they aren't sheared off, they are fine.
Did you get coolant into the oil? If not, don't worry about the bottom end. (change the oil though..... I think getting coolant in there while pulling the heads is simply unavoidable.)
50/50 should be fine.
Replace the thermostat.
I advise staying stock temps though, that is what the PCM expects, and what it is designed to run at.
Ya know, fair enough, and I appreciate the honesty, lol
Overall not top bad of a kit. When you get your timing chain kit,, make sure that (if it's included) you DO NOT put the metal plate behind the tensioner on the passenger side of the motor...learn from my mistake...here is the link to my write up, look at the bottom of my post for clarification https://dodgeforum.com/forum/1st-gen...ck-to-her.html
Steve
