Cold starts
Old Dec 14, 2021 | 01:41 PM
LanceMac's Avatar
LanceMac
Default Cold starts
So my 2000 Durango every year around this time of year my truck does not like to stay running. Ill start it and let it run for 5 or 10 minutes and ill go to take off but as soon as I hit the brakes it wants tl die. No check engine light so Im stuck and dont have idea where to start to look to fix it, does or have anybody else had this problem?
Old Dec 15, 2021 | 10:45 AM
What engine?
Old Dec 15, 2021 | 11:31 AM
LanceMac's Avatar
LanceMac
What engine?
4.7 I thought it could be a vacuum line but not sure
Old Dec 16, 2021 | 04:09 AM
Dodgevity's Avatar
Dodgevity
TPS and or IAC valve.
Old Dec 16, 2021 | 07:02 PM
sporta's Avatar
sporta
Following this one....the wife's 2001 Durango with the 4.7 is a cold hearted beastie in the mornings....as long as you keep on the throttle she runs fine. Usually takes about 10 minutes of either driving or warmup to keep it running...once warm, no issues. Could the IAC be needing a cleaning on this or would it be a TPS not showing a "true zero" at idle that is causing the issue (last time I checked with a scanner that would read TPS positioning, I think it read something like 12% throttle at idle with no foot on the gas) ???
Steve
Old Dec 17, 2021 | 10:02 AM
Steve
More likely a dirty/weak IAC than TPS.
Old Dec 17, 2021 | 03:51 PM
Dodgevity's Avatar
Dodgevity
The IAC clean costs almost nothing, so I'd start with that. If you see an improvement after cleaning, I'd still replace it.
Back when mine started cutting off, it did it while coming to a stop and it didn't matter if the truck was cold or not. Cleaning the IAC helped for a minute but I didn't see a marked difference until I replaced the TPS. The TPS replacement completely transformed the way the truck drove. Not only did it stay running, but the power delivery was smoothed out and the truck drove like a big Caddy. Prior to this, pressing gas was a herky-jerky affair but I wasn't really aware of how bad it was till I replaced it. Stick with mopar on these.
Old Dec 19, 2021 | 08:07 PM
LanceMac's Avatar
LanceMac
WI'll idk if it matters but I randomly get the 455 code for the EVAP leak could that have anything to do with it
Old Jan 13, 2022 | 12:56 AM
Johnny Good's Avatar
Johnny Good
No, the evap code is not related. Sounds like the IAC valve. Two weeks ago my 2000 4.7 started dying at stop sign/light. It got worse as the days went by until the point where it would start and immediately die. I could give it gas to keep it running but did not drive it like that and let it set for a few days until finally got around to it yesterday. Replaced the TPS sensor and no change. Took off the IAC valve and started it. Engine roared to about 1800 RPMs but did not die. Shut it off right away. Inspected the valve and the plastic that hold the plunger was cracked in two places. Replaced the IAC and it's good to go.
Old Jan 13, 2022 | 04:41 AM
LanceMac's Avatar
LanceMac
I already replaced the IAC and TPS and it's still seems like it wants to die but it hasn't got as cold as was since I replaced them.
