03 Durango SLT+ 5.9L Radiator Fan Relay
Old 01-22-2022 | 08:54 AM
jims's Avatar
jims
Does your SLT have a overhead computer console with display screen ? I thought they were standard on the SLT and that's where the ambient temperature would be displayed... if you have it
Originally Posted by coondog28
I don't have an ambient sensor. And according to the wiring diagram i should not. I will take a look at the expansion valve sensor.
Old 01-23-2022 | 04:40 AM
Dodgevity's Avatar
Dodgevity
Does the AC work?
Old 01-30-2022 | 06:18 PM
coondog28's Avatar
coondog28
Problem solved!!!...Not a problem.
It was not getting the engine hot enough. By connecting my scan tool it runs at about 185. Even with a 195 thermostat. It's cold here so no surprise.
So I blocked the radiator and turned on the ac. It was tough to get it to heat up but the radiator fan kicks on at 205. I didn't bother seeing where it turns on with no ac commanded. From my research 210. Have to wait till summer to see. I am sure it will turn on whenever the computer decides it needs to be on.
A little piece of mind that the fan will work when it is needed...i.e. Chicago traffic in the summer.
Cheers...
