Engine running ruff
Hello all, I'm new to this forum!
Need help, my 2000 5.9l Durango engine is shaking quite bad during start up/idling. Even when driver's door is open, you can see it, like how a muscle car rumbles.
also as I accelerate, you can hear and feel it.
What I've done to it so far,
:replaced spark plugs, wires,cap,rotor and ignition coil, and all 8 injectors.
Thanks in advance
Thanks in advance
Trending Topics
Hello HeyYou, so I changed out spark plugs and reset pcm. Unfortunately no change. Did a compression test and that is all good. Seems like maybe it's not the engine?
when start up, the engine and car shakes, and when I step on gas at idle or accelerating, you can hear the car rumbling. Like something is unbalance.
What arr your thoughts.
thanks
thanks
Cheap and easy.
