Rear differential fill location?
I need to put in some of the LSD additive in the rear differential and I wanted to be sure that I am using the right location to add the fluid. Looking at the rear diff cover about 2/3's of the way down on the right hand side there is a rubber plug, I'm assuming this is where you fill the diff and check the fluid level?
Also on a side note does anyone know what the correct gear oil is for the rear diff just in case?
Thanks
Thanks
ORIGINAL: hydrashocker
Go completely Full Synthetic. Dodge rear axle additive. And yes you got the right filler location. I thought we used 80-90W tho.[sm=feedback.gif]
i was under the impression that if the gear oil was a gl-5 rating or higher that the LSD additive wasn't needed. could someone please verify this?? whttp://www.klotzlube.com/tech/KL-508.pdf
this is the fluid i was thinking about using.
That stuff is crap. You need the additive. Go with Mobil-1 75w-90 with additive.
Trending Topics
why is it crap?? so your saying i do need the additive even though it is a gl-5 rating or higher?? i run klotz in my sportbike, dirtbike, wifes bike, etc,etc. why are you saying its crap?? have you ever used the stuff?? oh well thanks.
