Code Readers and Scanners
Old Oct 12, 2023 | 11:34 PM
sporta's Avatar
sporta
Default Code Readers and Scanners
Hey all....
Looking for some input in regards to OBD scanners and code readers. From my understanding the stealership uses an OBDIII tool to read our Durango's. Is there an affordable aftermarket tablet/scanner/reader that will do all the things that the OBDIII at the dealership will do? Specifically I want to look into the TCM on my '00 Durango as well as being able to program remotes/keys for the '01. I have been looking on Amazon for something similar to the OBDIII such as
Amazon Amazon
I have seen emulator software out there for sale but that is 3k plus a special laptop on top of it....
Anyone have any suggestions?
Thanks
Steve
Old Oct 14, 2023 | 09:06 AM
The one you linked doesn't look too bad, there are better (and worse) scanners out there, but, you pay a premium price for the really good ones.
Old Oct 16, 2023 | 10:50 PM
sporta's Avatar
sporta
Is there anyplace that describes the difference between OBDII and OBDIII that the stealership uses? My neighbor has a Autel scanner with all sorts of adapters (similar to this one: https://www.obdprice.com/products/au...stic-scan-tool) but at times he cannot see stuff the dealer should be able to....am i missing something?
Thanks
Steve
Old Oct 17, 2023 | 08:18 AM
I don't think OBDIII is a thing yet. Dodge dealers used to use a DRBIII though?
Every manufacturer has some 'specific' stuff in their programming, that you need a fairly high-zoot scanner to read/play with. And that is only getting worse with literally EVERYTHING being computer controlled/influenced..... You can spend thousands on a scanner, and there will likely STILL be things it won't do....
Old Oct 17, 2023 | 09:28 PM
sporta's Avatar
sporta
Sorry about that, you are absolutely correct, no OBDIII but DRBIII....was tired when I posted it last night.
Old Dec 30, 2023 | 01:21 AM
DodgePickles99's Avatar
DodgePickles99
Default Drb3
I have a '00 5.9 R/T in Px-8 black..
I am looking to get this durango keyfob ( correct PN ) but it isnt paired with the car . I am also looking for a DRB 3 Scan tool... also tryna fix my front passenger side window seems to not work
Old Dec 30, 2023 | 09:58 AM
Maybe Ebay? They come up every now and again.
