Rear Freezer Plugs - Bell Housing
Old Nov 29, 2023 | 08:02 PM
2000 SLT's Avatar
2000 SLT
Default Rear Freezer Plugs - Bell Housing
I think I have a leak where the freezer plugs are and where they meet at the motor/transmission. I know I’ll need to pull the transmission down. But before I do that, how do I ensure 100% the leak is there? I see coolant dripping on the two bell bolts but not in the weep hole. The other day, I must have leaked coolant and it almost over heated. Saw a big puddle under it. I tried to do a pressure test in the cooling system but it couldn’t hold pressure. I inspected the whole engine and couldn’t find a leak. 2000 4.7 Thanks!
Old Nov 29, 2023 | 08:10 PM
Refill the cooling system, and re-pressure test. If it's coming out between engine and trans, (and make sure it isn't coming off the heads, mirror and flashight come in handy here....) then you have to drop the trans. Keep in mind though, that if one is leaking, all the rest are not far behind, so, replace as many as you can get to.
Old Nov 29, 2023 | 08:22 PM
2000 SLT's Avatar
2000 SLT
Can I just remove the inspection plate to really look at if the leak is coming from that area? And how filled does the coolant system need to be to pressure test it? Mine was at the Full line and all I could hear was a faint air leak, no coolant bubbling or leaking, on the driver’s side about halfway down.
Any tips on removing the transmission? I’ve never done one but have friends to assist in the muscling.
Old Nov 29, 2023 | 08:24 PM
2000 SLT's Avatar
2000 SLT
Also, I cannot find the correct size for the freeze plugs in the bell housing. I’m assuming I can buy the kits off of RockAuto and those should fit?
Old Nov 29, 2023 | 08:48 PM
Run the engine with the radiator pressure cap off till the thermostat cycles at least once, then make sure it is actually full. Shut it off, pressure test. See where the coolant is coming from. If there is a lot of air space, you will be pumping a LOT before you start to build pressure, and if the leak is above the coolant level in the block, all you will get is air. Make sure your pressure tester actually SEALS to whatever it is you are plugging it into as well.
The kits should have all the correct sizes.... at least, you would like to think so.
Old Nov 29, 2023 | 09:10 PM
2000 SLT's Avatar
2000 SLT
Thanks! I’ll try and do another pressure test done right. If it ends up being the plugs in the bell, will a pressure test even show that leak? That’s pretty far down. I’m also still curious why no coolant is coming from the weep hole rather the two bottom bell bolts?
Old Nov 29, 2023 | 09:11 PM
2000 SLT's Avatar
2000 SLT
When it leaked bad the day I stopped driving it, coolant made its way to the back.
Old Nov 30, 2023 | 10:01 AM
Hhhmmmm.... .see it there tends to make me think it is NOT a freeze plug. I would indeed expect to see that coming out the weep hole..... Are there any hoses or other types of coolant plumbing back there???
