Misfire an running rich 99 durango
Old Dec 27, 2023 | 08:32 PM
Myboyblue53's Avatar
Myboyblue53
Default Misfire an running rich 99 durango
Hey everyone I just got a 99 durango I have a miss an its running rich but the scan just saying multiple misfires could the map do this or th o2 sensor s has new plugs wire cap so on new sensors on the throttle body except map sensor if I'm just barely giving it gas it's OK but starts misfires when I give it gas the only other thing I need to replace is the disc looking thing in the distributer I can't recall the name of it but can look if someone needs to know. It is running rich an I thank that's thats cousin the misfires
Old Dec 27, 2023 | 08:42 PM
Which engine? What plugs got installed?
Old Dec 28, 2023 | 11:52 PM
Myboyblue53
5.2 an cheap auto lite plugs i was thinking it was them the owner from before just put them in right before I got it I been thinking about buying some good ones it had plugs wire in wrong spot when I got it it ran ok for few days after i fixed that then done same thing
Old Dec 29, 2023 | 09:09 AM
The autolites are likely just fine. These engines really don't care for the rare earth plugs. You end up with mystery misfires.
What kind of shape is the cap/rotor/wires in? May also want to take a look down the throttle body, into the intake, see if you see oil pooling in there. (common problem on the magnum engines.)
